Cooling fan quit working!!
designie
Shelby, MI
My cooling fan quit working about 2 months ago, but here in Michigan, it didn't matter... yet. Now it's getting warmer.
I tested the motor which I replaced last year, it works. The main fuse on the firewall is ok. I replaced the relay box last year. Anyone know what else could cause it not to go on? Even when I run the defrost or air, it doesn't come on, which it normally would.
Any ideas? Thanks!!!
<small>[ April 16, 2003, 05:00 PM: Message edited by: designie ]</small>
Levand16
San Antonio, TX
This just happened on my Sable... The first problem I had was the car won't start. I replaced that "relay" box on the radiator support and the car started but no cooling fan. I checked out everything and in the end it turned out to be the new relay box I had just put in was bad. Replaced it and the cooling fan worked fine.
BTW- did you try jumping the temp sensor?
rangerj
Brunswick, Ohio
Ah, Steve, wasn't it also Mark Twain (aka Samuel Clemens) that said "you can lead a horse to water, but you can't make hime take a bath"? Or something like that! :D rangerj
