Gauging Interest in CAI group buy. Pricing should be in the $100.00-$200.00 range depending on number interested. The filter is heat sheild and cool air is drawn through the fender hole by means of a velocity stack. The stainless steel construction is very elegant, rust resistant, and can be powdercoated. Some of you may ask why not plastic? Stainless steel is more durable given its metal nature and therefore can be made thinner than plastic optimizing volume in the cone area. Thermal coatings can be applied for the serious minded people.
The kit:
Cotton or Stainless Steel 6 inch filter. Stainless Steel Canister. 45 Degree Hose w/Polish heavy duty bolt clamp. Fender Velocity Stack.
Kit should work with any current MAF setup.
A prototype system is on a fellow SHO members car right now. "St. Louis SHO" Please feel free to ask opinions on the system.
The system offers the convinence of easy maintance. Lower dirt exposure compared to fender style systems. Engineered to provide the highest flow than any other system. The MAF and Cone filter are allowed to move within the canister as the engine torques due to its non-rigid construction.
Intake removal should consist of simply undoing the throttle body clamp, pulling the plug off the MAF/Cold Air Sensor, and a quick pin on the side mount. <----Last part yet to be determined...?
I will build the second prototype of the unit next weekend. Any input on design would be much appreciated...
Right then...Whos interested...?
