Ok, here is my major update.
Mike sent me some needle bearings to help things rotate better.
Those were a huge help. They solved 90% of the binding. I put them on the top of the springs, but had to modify the bottom of the lower aluminum block part of the articulating mount. I used a die grinder with a square end, but it would probably look neater if you had access to a machine shop.
Now, I say it solved 90% of the issue, because the needle bearing on the right side binds a slight bit. For some reason the right one is always a bit tighter. I'm sure I just need to tweak something with all of the times I have taken them apart and put them back together.
Here it is together.
I aligned it today and set it at -2 deg camber. The minimum I could get was just under -2 degrees, so if you want less than that, you will have to flip the yellow blocks back the way I had them first. The maximum I could get that way was -1.75 deg.
One thing I would suggest is to replace the washers that hold the nuts on the top. They tend to bend a bit, and after taking apart and reassembling multiple times, mine started to crack. I put some thicker ones on there while aligning it.
All in all, I am very happy with the setup. I hope to autocross with it soon, but I also have a growing family and a lot of family obligations as well.
I also want to thank Mike (and the other guys) from SHOsource for all of the help. They did everything they could to make me a happy customer! Thanks again!
