CODES FROM A 93 TAURUS with SABEL motor
BETTY DAVIS
Toronto, Ontario, Canada
The Check Engine Light turns continuesly on when driving between 40 - 80 km/hr with no noticable change in performace. The results from the KOEO test are as follows: 113,171,172,181,628,646,647. The results from the KOER are as follows: 411, 538. Although not a SHO, but a distant cousin, support would be appreciated in trouble shooting the problem.
BETTY DAVIS
wood_e
The dude
Ames, IA
113 - IAT sensor is/was high or open
171 - Oxygen sensor not switching - system was at adaptive limits - Single Right or Rear HO2S
172 - Oxygen sensor not switching - system is or was lean - Single Right or Rear HO2S
181 - Fuel system was lean at part throttle Single Right or Rear HO2S
411 - Idle speed system not controlling idle properly (generally idle too high)
538 - System did not receive "goose" test
628 - Excessive converter clutch slippage
646 - Transmission 2nd gear failure
647 - Transmission 3rd gear failure
Get a new IAT sensor, and new O2 sensors
Reset the computer and see if anything else comes up!
If your temperature was below 50 F, do NOT replace the IAT. Ignore that code.
Start with the resetting and see what pops up first.
