Well Matt, this is the 96-99 SHO section.
But, to answer your question... wink
There are a version of the 17" Cobra wheel that will fit a SHO, as long as the bolt pattern is 5x108mm or 5x4.25" (sometimes called a Thunderbird fitment)
If you go onto eBay and look under the automotive section and look under '17 chrome thunderbird' you'll find a nice selection of wheels available.
Honestly, I think that a 215/40/17 tire is way too short for any Gen SHO. I have 215/50/17 on my 97 and they handle and look awesome on my 17x7" wheels. I would recommend that size for a 17" wheel.
Also, seeing that you have a Gen 1, there are many cases when people have to trim the rear fenderwell somewhat when putting aftermarket wheels on. Make sure you check into that before committing lots of $$ to a set of wheels.
Offset, too, is critical. It shouldn't be an issue with the Cobra wheels because most of them that fit the SHO are roughly 40mm offset. Usually if you stay around 38-42mm you'll be okay.
<small>[ October 30, 2002, 10:38 AM: Message edited by: wuzzzer ]</small>
