Bank of SHO
Having the car apart a second time, I can't find any problems so far. Before I reinstall the tranny, is there any way to be sure it is working correctly? How easily should it shift by using a punch in the shifter stub? Is there any reason at all you can think of to blame the tranny for the bad shifting I was having when the car was running?
The flywheel and pressure plate were once again tightened a little at a time in a cross pattern and in stages with a torque wrench. The clutch disc was centered as close as I could see/feel it. Should the pressure plate and flywheel be touching at the bolt mating surfaces? There is a VERY slight gap between them around the dowl locations. I assume this is the aluminum flywheel deforming a tad.
