SHOMA
I also have a 92 MTX, just purchased it, fixed minor suspension work, and its done... Clutch grabs barely off of the floor, have to consciously hold clutch to floor, to avoid grinding into gears. YET, you can not make the clutch break away or slip, and usually bad clutches would grab on top, correct? Is the cable adjustable........?? Thanks in advance!!!
