mine too!newdy22 said:I have the same problem... so I bought new strut mounts to fix the problem... and everything else since it was going to be apart. I bought the "NotSoSlowSHO Suspension Package." Moog strut mounts, coils, endlinks, Monroe struts, and FoMoCo pinchbolts. $638 from RockAuto. The pinch bolts came from shonut. I think that should fix it.
newdy22 said:Everything has been replaced and I still have a rattle in the rear, although it is nowhere near has loud as before. It is still there though. I took the spare out and then took a spin. Still have the noise. I checked the amps and they all seem secure. Arrrrg.![]()
newdy22 said:I found the culprit for the noise in coming from the rear after the suspension overhaul. I noticed the trunk had about a half inch of play when closed. I adjusted the catch in the trunk that is mounted to the body of the trunk down. I also brought the the rubber stops out two full turns. The noise is GONE!!!![]()
for a ride."
