Cloyes Timing Belt?
TYSHO
Earth
About the crank mark, are these suppose to come with only 1 aligning mark, not 2 for the 3.0 and 3.2?
I looked up on RockAuto and it lists the same Cloyes B248 for both ATX and MTX.
Is something wrong here, or can the same mark work with both? :confused:
BTW, the belt has 202 on it.
SHO#7
Cincinnati
The belt I bought at napa had one line that read 3.2 and one that read 3.0
Mike
gbizzle27
Bradford, Pa
All the aftermarket belts i have seen have had both 3.2 and 3.0 marks on them.
Just line them up to what size motor you have, and your ready to go.
Yamaha V6
SHO Enthusiast
Rhode Island
The 202 is marked for one motor only, the 248's are usually marked for both. I personally use Gates, myself, which is most definitely marked for both on the T-248.
TYSHO
Earth
With that said, what is the 202 intended for, atx or mtx? I went to rockauto.com to see if they had 2 different ones for atx or mtx only, but no luck, they all list the same.
For the others, I was asking because I only have 1 line without markings for a 3.0 or 3.2. There's 3 lines total, 2 for the cams, then the unmarked one for the crank.
K-Dawg
Treasure Coast, FL
Do you have another to compare it to?
The 248 part number means it has marks for both belt setups. If it only has one mark it would make sense if it was for the 3.0 MTX.
TYSHO
Earth
Only an OEM 3.2, if I didn't throw it away when I cleaned the garage out, but I think I did, no point in keeping an old belt.
myculito
