autobahnsho
SHO Victim
TYSHO said:If you're recieving a clicking noise, the ignition wire to starter solenoid is feeding the starter with power.
I would double check that the wires are placed correctly and that you have a fully charged battery.
Even though you said you got new cables, for anyone else that reads this thread-
I had a SLO that only SOMETIMES didn't start. A new battery and lots of $$ later it turned out to be the negative cable from battery to starter was corroded inside. So sometimes the amount of juice necessary (which is A LOT) for the starter wasn't getting through. Cables are cheap.
Sounds like you're on the right track but I'd re-check everything. I think if the DIS is not grounded right it does funky things, too..
Good luck!
