Cleaning the K&N filter...
Smoof
Colorado
Curious, I got through the whole process and I put the oil on and let it cure overnight. I picked it up this morning and there was oil all over the paper towels I put under it and it dripped a few times. I made sure it wasn't dripping anymore when I put it on the SHO, but it's very oily. My question is, before I start-up my SHO, should I be worried? Did I oil it too much? Should I not start it up?
Smoof
Colorado
Am I fuxx0rd? Will I be able to start the car without sucking oil into my intake?
Mr Anonymous
Tire Wall
Let it sit on paper towels for another day or two just to make sure. Or, start the whole process over again.
Smoof
Colorado
Is there anyway I can make sure it's good so I can drive it today? I need it for today. It SEEMS as though most of the inside is dry as I shook it a bit and nothing came out, it's just the outside is so oily, my hands were covered in red when I finished putting it in...
Mr Anonymous
Tire Wall
Then just stick it in and drive. Worse-case scenario you'll need to clean the MAF filaments in a couple weeks.
Smoof
Colorado
So I don't have to worry about sucking oil down into my intake and screwing my engine?
Smoof
Colorado
Heh, well thanks for the responses guys. I appreciate it, I'm still automotively challenged (see: ********), but I'm learning, heh heh.
95SE
Lafayette, Colorado
ya, retard.. :bonk:
It won't hurt anything, just make sure to clean your MAF a coulple times.. You're intake runners will prolly get gunked up too, but its not the end of the world..
At least you know it will filter well!
Jeramie
revhardSHO
Seattle, WA
I would personally go back to a stocker dry filter. They have all been flowbenched and all do about the same. Ive never had good luck with K&N filters on SHOs. Seems they need to be cleaned all the time and fowel up the MAF every other day.
Smoof
Colorado
I bought it with the K&N so go figure, heh.
Hey, I might be ********, but at least I asked before I ****** it up :D
