cleaning egr
goalieman59
Learning Slowly
OFallon, IL
Ok so i have the intake off, but I cannot seem to get the hex bolts off the intake so i can get the crap out of the pipes. I can get to the holes got them cleaned out. But i want to make sure I dont have to do this any time soon. Thanks.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
You talking about the "plugs" ? Probally really hard to do if you don't have a bit for your ratchet... I think I had to use the 1/2" to crack em loose on the intakes I've done before.. Or set the intake upside down on the ground on a rug or something and step on the allen wrench if thats what your working with..
goalieman59
Learning Slowly
OFallon, IL
Cleaned the EGR nostrils with out taking the intake off. I think i am still getting the 332 code I will check for sure tomorrow. I also put on a new DPFE while I was at it. I did not pull the plugs to clean all the way should I still do this? Or do you have any other ideas?
SHOtimer
#2910
Santa Clarita, Ca
I didn't pull the plugs on mine when I had the manifold off. The plugs seemed to be welded in there.....
But with the manifold off and a small pipe cleaner, some pick tools, and a lot of Chemtool, cleaned that manifold like it had just rolled off the assembly line.
The biggest problem area seems to be the small little passage ways near the throttle body, where it "T's".
Doug
Off Road SHO
Moderator
Yeah, I cleaned the horizontal passages ( one about a foot long under the rear "Y" plenum, and the two little nostrils inside the junction) till they were spotless, but untill I took the intake off and removed that bottom plug, I was never able to get rid of that code.
If you don't want to take the intake off and remove that plug, remove just the back plug, spray B-12 in there, and then push a stiff piece of wire in there. Push it all the way in and then cut the wire off so that about 3" sticks out the back. Form that 3" into the shape of a crank and turn away. The rotating wire will rub against the inside of the passageway loosening up the crud.
In conjunction with this, I extended the nozzle on the B-12 so that I could reach the nostrils through the throttle body. You can hold the throttle body open with a pair of needle nose vise grips. After I let the B-12 soak for a while, I took a bent piece of brake tubing and pushed it in and out of each nostril. Eventually I was able to get some of the B-12 to soak down and loosen up the crud in the little 1" long verticle portion of the passage way.
It was a long process.
Tom
goalieman59
Learning Slowly
OFallon, IL
Thanks Tom I think i got the code to go away, by putting a old DPFE back on the car insted of the new one from Orileys.
