smcallis
What do you do to check rod bearings? Do you check clearance and look for wear like with the valve shims? What happens if you find an out of spec rod bearing. My local shop says you have to send the crank out to be ground and reinstalled with thicker bearings. From other posts I've heard it didn't sound like a big deal. My RMS is leaking again after 30k miles and I'm beginning to wonder if it could be due to excessive crank motion.
Thoughts appreciated.
Sean
<small>[ June 04, 2002, 03:25 PM: Message edited by: smcallis ]</small>
Sean
