Changing AC Pressure switch under pressure?
Twisted99
South East
Can this be done or must it be evacuated. I have a new switch for the ? discharge one right next to the rad/overflow bottle. Noticed a set screw in the switch should this be left alone or tweaked. Thanks
Ishodu
The cycling switch, you just twist it off, there is a shadier valve under it, you may get a tiny piff but thats it. Good idea to change the O-ring too when you change the switch. My replacement came with a new one.
clindahl
Raleigh, NC
Correct, the pressure switch can be changed without evacuating the system. Why are you changing the switch though and wondering about the set screw? Since you have a 1995 your car came w/ 134a, so there SHOULDN'T be any need to adjust the pressure. When I did a conversion on my 1993 from 12 to 134a, I backed the pressure down a little bit from what looked like 25 to about 20 PSI before it cut out, makes things nice and cool :)
Twisted99
South East
Not changing the freon.....just had the new switch sitting around and changed the clutch/coil so....I stuck in the switch...
