I just changed the Trans. filter in my 93 atx and noticed a loose tube when i took the filter off.
Has anyone noticed this before. My Ford service manual calls it the (Reverse **** Tube). The tube
is up in the hole but not all the way. Its tappered so you would think that it should fit tight but it don't. The book specifically calls for a tool (**** tube remover and impact slide hammer) to remove the tube so that right there tells me it should be snug and not loose.
Just wondering if anyone else has noticed this.
Trans does not seem to have any problems except for the hard 1-2 shift and unexpected down shifting while driving.(changed the VSS last week to see if that would help but the hard shift is still there, but i think the downshifting problem is gone) VSS out and back in less than 2 hrs with two people.
Well if anyone knows please respond..........
