farley556
My CE light flashes on and off rapidly when i press the throttle. It does this when i accelerate and in low gears. It also flashes when I am in high gear coasting and i press the throttle down hard. The flashes are fast and have no pattern or anything. The lights very dim, med dim, fully lit up, etc. This is not suppose to happen right? I checked the codes, nothing. i had some problems in the past with the ABS and wires burning up, so i pulled fuse to ABS, no more ABS. I dont know if this has anything to do with it but i thought i would mention it. Also I know i have a bad 02 sensor and i going to replace them along with plugs and wires. I also have a bad starter as well, and will be replaced in a couple of days. What could be causing this? electrical problem? I have posted something about this before but thought i would do it again with more detail to see if i could come up with better results. Somebody said it could be the o2's but i dont know. Please help me! Thanks!
