Marccus
'89 w/438K
When starting a cold engine, a get a racket of noise, like tumbling rocks, in a metal container.
When I crawled under the car when first started I heard the racket of noise coming from one of the catalytic converters.
I'm assuming that the catalyst broke loose from its bed or container and that is what is causing a racket.
When the engine is warmed up, you can hardly hear the noise, probably because once the catalyst expands from the heat there is less room for it to bang around.
I have a Performance Plus Y-pipe that is about 17 years old.
Can I cut old the damaged catalytic converter and weld in a new one?
Where can I purchase a new catalytic converter?
Thanks.
Thanks.
