Car is Running VERY RICH
SHO_ROLLER
Florida
And I don't know why. I have new O2 sensors, new plugs, and a new ECT sensor. I tried to run the codes but the shop can't read them because my slush module is shot. Any ideas what it could be?
Anthony :cry: :shrug:
ckinart
Mississauga, Ontario
How do you know?
Anthony,
Not that I'm doubting you, but if you can't check your codes, how do you know your engine is running rich? Have you checked your fuel pressure?
Mr Anonymous
Tire Wall
What exactly is a slush module? :shrug:
You don't need a shop or any expensive equipment to read your own codes, all you need is a paperclip or short piece of wire, and the DIY instructions from any one of the three sites in my signature to learn how to read them yourself.
After reading the codes and determining if there are any other factors causing a rich mixture, you might want to next investigate your thermostat to see if it is stuck open. What temperature reading do you get on your dash gauge when the car is fully warmed up?
TheKrazyRaven
4 8 15 16 23 42
Lawrence Massachusetts
my car was runnong VERY VERY VERY rich, was throwing codes for o2's so i replaced both, some improvement
then someone suggested a new ECT, so i switched it out, agian some improvement
then yesterday someone suggested i inspect the t-stat to see if it was stuck open and indeed it was so i put a new one in yesterday and filled the tank and reset the trip OD to see if theres any improvement
Satchmoz
