Can I do my mufflers?
Vito117
Iowa
I've never replaced mufflers, is it a major project?
Any cutting torch or welding gonna be required?
jthomas68
Area 51
You`ll have to cut off your old mufflers.The new ones can be welded on,or you can use clamps instead.Obviously,welding is better,but you can get by without it.If you go the clamp route,i`d wouldn`t use the cheap slices and muffler clamps.Go to summitracing.com or jegs.com and order the Dynomax muffler straps,they are a bit more,but worth it.
<small>[ April 20, 2003, 12:32 PM: Message edited by: jthomas68 ]</small>
shojuan
sunny San Juan Bautista,
If you're going to use clamps get some Walker muffler seal or whatever the **** the stuff is called too. I need to get some of that and use it on the clamp joints of my y-pipe. Seals it up and makes it leak free.
