Fred you are correct. The hollow shaft would most likely not distort though, b/c it is heat treated. It would most likely shatter or crack at the point of the highest stress. A non heat treated hollow shaft would most likely distort before the welds failed, though.
Heat settings would be slightly lower for a hollow shaft vs. a solid shaft, but just for purposes of minimizing warpage.
To answer the original question posted, use three welds, about 3/4" long, 120 degrees apart. Spot welds will do nothing to add to the integrity of the assembly. It's important to remember that a weld's strength is measured in PSI, so the more square inches of weld applied the better, but we don't want to overdo it in this case, to minimize/avoid any warpage of the shaft.
Just MHO. thumbs_u
And get yourself over to V8SHO.com and sign up for the email list. There's a ton of information on there.
<small>[ February 28, 2003, 12:31 PM: Message edited by: Bob Gervais ]</small>
