JRA2000TL
The Complainer
After replacing the far rear cam seal and valve cover gaskets, I still seem to have some oil burning/smoke coming from the far rear corner on the passenger side. I checked the area around the cam seal, and it appears dry. I was extra careful when replacing both the seal and the rear vcg. I even felt around under the rear cover after I replaced it to make sure I didn't roll the gasket.
The smoke smells like burnt oil still and is not too heavy; in fact, I couldn't see it coming from the hood when I parked at work this morning, but if you open the hood, you do see some coming from that one specific spot. I'm just worried the car is going to catch fire.
Should I yank the rear valve cover and put some RTV all along that back area on the gasket or the head to seal it better? It won't take but 15 min. to remove the intake, and I think I'm going to replace the wires anyway if I have to pull the intake once again.
