Reference the earlier post about stumbling, bucking at constant speed with slight applications of throttle.
Thanks for the heads up on the wiring, the number 5&6 wires were swithched on the wrong plugs. hard to believe I didnt notice it before. Switched them, and guess what. Now she really runs bad, even at idle I can even hear mild misfiring and smell a real rich condition. I am really beginning to think the wires, plugs and quite possibly the coil pack need to be replaced. It seems as if a couple of cylinders are not even getting a proper burn based on the misfire and rich smell.
I have the wires and plugs on order. The coil pack is just screaming to be replaced with that suspect spot I found, but I bet it aint cheap!!! I had a coil pack go bad on another car and it ran like **** until I replaced it
For those of you suggesting the cam Position Sensor....I have not ruled it out. After the wires, plugs and coil pack there isn't much left!!!! ANy more feedback based on the new developments are always appreciated.
Boy I'll tell ya..I never thought I would own a car with such a mysterious problem ailing it. I feel the end coming soon.
