1slickRED89
Guest
does the shosop & fps kit have a provision for blocking boost from the brake booster? just seems like boost pressure might have a negitive effect on the vacum powered assories. any input? thanks! Corey
1slickRED89 said:does the shosop & fps kit have a provision for blocking boost from the brake booster? just seems like boost pressure might have a negitive effect on the vacum powered assories. any input? thanks! Corey
1slickRED89 said:so your saying no changes are made on the shoshop/fps cars as far as vacum assories are concerned?
Lupo said:I made a pressure switch that activates and closes the valve for the charcoal cannister under boost.
Other than that, just cap off the 2 PCV passages, one on top of the intake, and one under the TB, so boost won't go into your crankcase!![]()
Dr.Evil said:So how do you releave crankcase pressure? I filter breather cap for the oil filler hole? If so, what about the other bank?
Lupo said:You opened up a can of worms there!!!
SHOShop, and many people simply T these lines together with a breather filter. This works, but does not ventilate the crankcase the way the PCV system is supposed to work. Also putting a vacuum to the crankcase is said to increase HP.
I have a vacuum line from my intake that sucks from the crankcase, and goes through a catchcan to catch the oil.
Im probably going to use an electric air pump to get a vacuum, so I can eliminate oil/vapors from the intake altogether.
I've discussed this at length with Josh from SHONUT, and I don't think that there is any proper answer.
Dr.Evil said:I tried removing the valve cover to TB line and replaced it with a K&N breather. I also hooked up a breather to the under TB line. I don't think it did a very good job because it cause oil to leak from the front main seal. With the stock system in place, it was fine.
BTW is that your deep sump SHO pan in the link on your sig? That thing looks nice!
