Brake Bias Plugs for '89 SHO - Safe to Drive?
DeepPower
Searchng4Truth
Texas since 2013
Has anyone put the SHOSource bias plugs on an '89 SHO (non-ABS) for road use? What does it do to the rear brakes - is the car safe to drive? Would performance brake pads on the front help?
As an option, can the bias valve w/o the plugs be adjusted way in one direction?
I think the (new) brake bias valve is preventing my rear brakes from engaging. Mechanic is trying to diagnose.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
The bias plugs increase full braking in the rear so if you have an extreme case where the rear picks up like in a panic stop you can get them to lock up easier.
DeepPower
Searchng4Truth
Texas since 2013
Hmm... maybe if I did something to help the front brakes bite sooner it would be more balanced. What are the best brake pads I can put on the front?
Hawk HB240F.620 HPS brake pads maybe?
DeepPower
Searchng4Truth
Texas since 2013
Yep, I was told if you really stand on it, the rears will lock up. So I want the best pads possible for the fronts.
LOUDSHO92
Sponsoring Vendor
jayro
Auburn, In
IIRC the rod on the bias valve is threaded and adjustable. You can also remove the rod and use a zip tie or band clamp to hold the stock valve open so you still have max flow to he rears at all times, although I believe the bias valve wide open only allows about 60% to the rear. This is what I did prior to my bias plug install.
If you are worried about your rears locking, you should think about weight transfer etc while braking. Performance pads in the front could cause more transfer to the front and unload the rear.....causing them to lock up easier. How is your suspension? How much nose dive do you get under hard braking?
And most important, what is your end goal?
zak
east of Hartford
The 11 inch (94-95) or 11.6 inc (96+) front brakes will help balance the front bias, but require the 94 or newer front hubs. Even better is to adapt the 98 or newer front Taurus subframe, control arms and spindles, which will reduce front dive on braking and get even more work out of the back brakes/tires. The later Tauri (I think after 2000?) don't even use the rear brake "bias" (actually a shut-off) valve at all.
DeepPower
Searchng4Truth
Texas since 2013
They have ABS, so bias isn't necessary because the computer handles exactly how much braking each wheel gets.
Are those the HPS, HPS 5.0, or HPS+?
http://www.hawkperformance.com/street-performance-compound-application
Also, I thought the purple Hawk box was only for calipers with a phenolic piston.
Well, end goal is to get my rear brakes working!!! Tony Huerta at North Texas Performance is supposed to be an SHO expert, but he's been complaining to me for three days that he couldn't get my rear brakes to work and that the rear tires spin on braking. So he's been charging me $$$$ for a new master cylinder, brake lines, brake booster, etc. Like I said, good mechanic, but I have serious business-related concerns. He's had my car for four months.
He claimed he checked the bias valve, but when I demanded he test by putting the bias plugs in suddenly, hey, surprise, I have rear brakes! But I do not like the idea of the rears locking up on a panic stop. I have a 45 minute stop-and-go daily commute and a panic stop is possible.
@jayro, I like your ides of removing the rod and using a zip tie. 60% to the rear like that? How is the car in a panic stop (non-ABS)?
zak
east of Hartford
Is he jacking up the left (drivers) side rear suspension when making these brake tests? Unless the suspension is compressed the "bias" valve will remain closed and block flow from the master cylinder.
DeepPower
Searchng4Truth
Texas since 2013
Yes, Tony first claimed he jacked up the LR suspension (to close the bias valve), but when the bias plugs worked I ended up not believing he jacked it up. At this point I need to give him exact instructions or I do not trust he'll do the right thing.
jayro
Auburn, In
I think what he meant was that unless the suspension is compressed the rear brakes won't work since the no fluid will be reaching the calipers. From what you have said it sounds like the bias valve is the issue. Either it was out of adjustment or the valve was faulty.
It says you are in Texas, so ice and snow probably is not an issue. If you drive smart I don't think you would have issues with bias plugs. Just realize that you could have the back end come around. Front pads with more bite might actually cause this to be more of an issue. The aggressive pads would cause the nose to dive and unload the rear tires. The lighter weight on the tires can cause a lock up. The front does the majority of the braking, so 60% at the rear didn't seem to reduce my braking at all.
I run bias plugs on my 94 with aggressive Carbotech pads and a '96 Upgrade, but I have rear ABS and a stiff suspension that helps reduce weight transfer under heavy braking.
Irish Pride
Irish Inside
MusicCityUSA
My 91+ has 13" rotors with Cobra PBR calipers and Hawk HPS pads in the front and 96 11.6" rotors with Brake Best Ceramic pads in the rear. Ive had Bias Plugs installed with non functioning ABS for the last 2.5 years and havent had a single issue. You would need the absolute worst driving conditions Ice/Snow/Heavy Rain and a panic mode stop for it to be a factor. If you are ever driving in a weather condition like that then drive extra defensively and you have nothing to worry about. I personally avoid driving my 91+ in the rain because of the fender mounted intake and i dont ever drive it in the winter months but i do drive it very hard otherwise and it brakes perfect.
side note - I didnt disable my ABS. The light came on a week after the Ft. Worth convention and i just dont have the desire to diagnose/repair it. Thats how much of a non factor it is.
LOUDSHO92
Sponsoring Vendor
DeepPower
Searchng4Truth
Texas since 2013
I live in Texas and yes, snow and ice is not an issue but there is another issue. It rains maybe once a month here, but when it does rain, all the stored oil and grease from tires and etc that has not washed away from regular rain comes to the surface of the road in force, and it is exactly like driving on ice. It's a very serious condition.
Thanks for clearing that up.
I'm getting more nervous about the bias plugs.
I think I'm going to have the bias plugs removed and adjust the valve all the way to the end of it's travel.
DeepPower
Searchng4Truth
Texas since 2013
Not concerned about bias plugs anymore because when I went to see Tony Huerta to test-drive the car this morning, the brake pedal was very very spongy. Pedal goes almost all the way to the floor, much worse than when I brought the car in (brakes were perfect then). Have to really stand on the pedal to get the car to stop!
This is after a new master cylinder (tried four of them), brake booster, almost all new brake lines, new rear calipers (fronts are new as of June). Brakes were perfect when I brought the car in and now acts like there is air in the system after being bled a dozen times. To me the car is not safe to drive like this.
Any suggestions???
Which brake lines have not been replaced? Does the fluid level go down at all in the reservoir? Which MCs have you tried?
And watch out for swollen brake hoses ...
DeepPower
Searchng4Truth
Texas since 2013
All brake lines have been replaced. Didn't know there were different master cylinders - what are my options? What are the best? Tony even used the MC from his own car.
Told Tony this morning to replace the rubber lines at the calipers with steel lines. He hasn't called me back, which probably means it didn't work.
Can you explain "Does the fluid level go down at all in the reservoir"? Don't know what to look for.
Thank you!
I was wondering if there are actual fluid leaks in the system, whether it is brake lines, brake hoses, distribution box, what have you. If so, the fluid level should go down in the brake fluid reservoir, unless the leak is a pinhole leak. Observe the level in the reservoir, pump the brakes hard a few times, check the level again.
I assume the fluid is brand new also, because old fluid can also cause similar symptoms to a bad master cylinder. If a flush has not been done, that would be worth a shot.
Not sure what the options are on MCs, I do remember some posts a while back about avoiding certain brands, and reusing seals maybe? I will search.
As long as it was unopened and protected from exposure to atmosphere/temp extremes/stored properly it should have been ok. 5 years is the generally accepted shelf life under these conditions. If the container is metal and showing rust, that could definitely be an issue though.
shoster207
