Blend Door Actuator Failure?
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
So My SHO doesnt have heat, and i ran the EATC self test, it came up with code 02, which I thought was the blend door actuator failure, however i have no heat whatsoever, and the heater core is hooked up... IIRC when the blend door fails, doesnt it default to only heat...
Rockledge
Pluggin' away
Connecticut
There is no default temperature when the BDA fails. Whichever position the door is in when the BDA fails determines the temperature of the air coming out.
SHO SPD
SHO member #480
Naples, Florida
Happened to my 89 once. No heat what so ever! sucked bad $800 to get that fixed at the local dealership.
ohfosho
ontario SHOwner
ontario, canada
hey guys... does anyone have a noisyish blend door? i can hear mine moving all the time now when i set the temp to the mid range (i put mine on 21, 22, or 23 when its cold out...yes celcius!). the blend door seems to not stay in one possition, and sometimes at stops it settles for a few seconds.
