URLACHER54
can you use any other type of serpentine belt tensioner from any other ford or just the one for this car. 94 sho atx 3.2
URLACHER54 said:can you use any other type of serpentine belt tensioner from any other ford or just the one for this car. 94 sho atx 3.2
djcannon said:Ford, in it's infinite wisdom, made the tensioner aluminum, and the bracket cast iron/steel. Put these 2 together, and you get corrosion.
etc1006 said:I'm scratching my head on how to get the piece out of the hole....
etc1006 said:There was an ATX at Crazy Rays on RT1 in Jessup a couple of weeks ago when I went for my swaybar link...
Getting a drill in there might be a bear though. A dremel with a good bit would prolly do it though. I'll be keeping my eyes out for a tensioner. Til then mine is torqued down real good.djcannon said:That piece that is left in the hole is aluminum, since it came from the tensioner. It can be easily drilled out. Aluminum is soft.
etc1006 said:Getting a drill in there might be a bear though. A dremel with a good bit would prolly do it though. I'll be keeping my eyes out for a tensioner. Til then mine is torqued down real good.
