dkal:
shotimev6:
when i start up my 91 plus one of the belts squeal. im not exactly sure which one it is and it happens mostly on cold startups. it goes away in about 5 seconds. anyone else have this problem?
On my 95MTX I had my serpentine belts replaced when I had the timing belt changed. The dealer did the work and when I picked the car up I noticed a belt squeal when I started the car. I didn't know which belt was squealing or whether they both were. I did know when I started the car up and switched the A/C on, the belt squealed and continued to squeal until I turned it off.
I took it back to the mechanic and he tightened the belt, since the car was already warm the belt didn't squeal when I first started the A/C, it did when I was driving about 60-65mph.
I knew the belt wasn't tight enough because the belt squealed when the car was cold on initial startup.
I guess you have to determine whether the belts are in good condition, if they are have them tightened.
Have to determine which belt is loose.
Good luck.
Dkal
