masho95
got Zex?
Well the other day I went out to start my car and I disarmed the alarm only to hear a sickly chirping noise not like the normal chirp. Sounded like a dead battery. So sure enough I get in the car and put the keys in the ignition and I turn it to "run" and all the dash lights, chime, etc, dim all out. So I pop the hood and look at the battery. There was a TON of corrosion all over the positive battery terminal side! Looked like a little white pile of stuff all over it. So I wipe all the corossion off and hop back in the car. Same thing turn the key to "run" and everything dims out. So I go back and take a closer look at the positive battery terminal. The corrosion must have eaten away at the original positive battery terminal because half of the metal was missing from the circular part of it.
So my question is what is causing this corrosion on the terminal. I noticed it again the otherday!! It won't stop!
If you smell near the terminal it smells like rotten eggs, which I believe is sulfur. So ANY ideas on this one? Procedures to test whether it's the battery or something else in the system? Thanks.
