Battery Recommendation for the SHO
CTOESHO
DeKalb, IL, USA
Well, I found out that my Die Hard just Died. So, I need another battery. I was thinking Interstate Battery or Die Hard. What do you guys use, and what should I stay away from? Thanks
Mike
93MTX
SHOnuff93
Dublin, Ca
I use an exide nascar select, it has been good to me, and i got it cheap, it has 1000 cca a bit overkill but nice to have
CTOESHO
DeKalb, IL, USA
WOW! 1000 CCA. Is that bad for the SHO to have TOO much power? Or is it nice to have? What kind of battery dimensions will the SHO take? The most I've seen from a Die Hard and Interstate Battery that will fit the SHO is around 740 CCA. By the way, how much did you pay for your Exide Nascar Select battery? Thanks
Mike
93MTX
SHOed_up
Ann Arbor, Michigan
Whatever you get go for a dry cell type, no acid to spill. We've got an optima for our boat and it's great. I think it's only 850 cca though.
fredhurderjr
www.neshospecialists.com
I like the Exide Orbital tech designs now, but in the Monte Carlo I had a Nascar 1100, in the 93 SHO I had a Nascar 1000, and I have a sears diehard gold 900 (I think) in the 95 now. Far as I know, it only draws what it needs.
SHOtime93
Michigan
I need a new battery too and I have been hearing good things about a battery called "Yellow Top" or something like that. A guy at the local car audio place recommended it. $180. Anyone know what it is and if they are any good?
1993 White SHO ATX
Stock under the hood so far...
GTS Headlight covers
Saddleman Hood Bra
GTS Sunroof ventvisor
Tinted Windows
"SHO" windshield decal
"SHO" filler decals
400watt PPI amp and a single Fosgate HX2 12"
Powered by YAMAHA
ACV1081
Member #187
IA US
You gotta have deep pockets for those optimas! I was going to go with one but decided to go with the interstate instead. It fits perfectly & the last one was over 6 years old. With the money I saved I picked up my SHOSHOP CAI for $80 so it was pretty cool.
1004303681370 NEW SHO PIC 102901
~Adam Varney~ mailto:[email protected][email protected]</A>
1993 RED ATX(3 replacements) W/shiftkit, 17" Konig Reigns, 245/45/17 Goodyear F1 Gs, 26mm ASB w/poly bushings, SHOSHOP Cold Air Snorkel W/ K&N Filter.
Not yet installed: 24mm ASB, 70mm MAF, all 60K service items, & rest of the poly bushings. Soon to be G-teched to see where I stand.
olympic
Saskatchewan, Canada
Use the optima "red top" for car starting duties. The yellow top is for a secondary trunk mounted battery for a large stereo system.
J
Jeremy Hohn
Guest
red top optima... the only way to go...
Jeremy
1993 atx 122k miles
-PIAA headlamp bulbs (thanks Fratperformance)
-fish tanks installed
-fog lamp mod w/ blazer fog lamps
-6" 5% tint border on windshield
-black body filled lettering
-wclewis "powered by yamaha" badges
-Sho Shop Cold Air Induction Kit
-Lund blackouts front and back
-cincysho colgan half bra with "SHO" lettering
-KVR chrome cadmium plated rotors with carbon fiber pads
-Sho Shop cat back system with magnaflow chrome tips
-Performance Plus y-pipe
-TX personalized plates "SHO FUN"
-Shoshop underdrive pulleys
-Shoshop 80mm MAF
-60k completed by Sdpatt
-Redline atx tranny fluid and water wetter
94shoboy
south shore, mass, usa
i have the yellow top optima, a shitload of power, pumps the stereo heat, all the accesories and my street glows and asks for more. its 2-3 times the money of a regluar battery, but last 2-3 times as long and has twice the power.
olympic
Plus you can drain an optima battery dead without hurting their capacity. A regular battery loses most of it's capacity after it's been drained once or twice.
myculito
