Battery Light Is On
SHOSKI90
Tampa, FL US
The other day after I started my car, a 90 MTX, the battery light came on. I checked the voltage coming from the alternator, 13.7 or there about. The alternator IS charging. But the battery light stays lit. While driving and at other times, the light will flicker, or stay lit, or go off with no pattern. Does anyone have any suggestions or similiar experiences? Let me know.
1990 SHO, 5 Speed, New SHO Owner
Shoman94
Maine
Check the plug on top of the alternater. Mine did it before...I cleaned the connection and its been fine since.
'94 MTX Silver
Tokico Struts, Eibach Springs, Spmotorsports SubFrame Conn. 29mm ShoShop Rear sway bar, Shohop Cat back, Gutted box with K&N, '96 Brake Upgrade, White Face Guages.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I had the light one about a week after I toasted my alternator. It could mean something electrical is about to give. Sorry to be generic but you covered what I fried.
92 White SHO
HiRevs Competion Clutch
SHOSHOP Engine Mounts
Koni Shocks
StrutTower Braces
UD Pullies
Awesome Sound System
naval-avi8or
Chesapeake, VA
If you just started your car and you are only getting 13.7 its time for a new alt./volt reg. It should be putting out 14-15 volts. Your alt is weak. I've had this 3 times in 3 years. Also check your Batt before you install a new one cause it could just **** it as well. You can also take an amp clamp/multimeter and you shouldn't be pulling very much from your batt. (key off less than 1 amp). Engine running 10-12 amps. When the A/C comes on depending on where you set your fan speed around 50 amps with head lights 60 amps. If your doing alot of idle driving ie. stop and go the alt has a hard time keeping up if you have any undedrive pullys it makes it imposible.
<small>[ March 15, 2002, 07:35 PM: Message edited by: naval-avi8or ]</small>
