AutoTap Software AT2 OBD-II?
OzzmanNT
Dinwiddie, VA
stephen newberg
Ladysmith, BC, Canada
I think that this would plug into the same connector that is used by the Ford diagnostic computer. It is in that pile of electronics under the dash somewhere. Since I did not have their computer I have never looked closely when they were hooking it up, though they do get power from the cig lighter. If you get this software and interconnect, please keep us informed. I might want to pick it up also.
pax
smn
'98, Black
Mod.Porter intake, K&N panel, SARC cutout, instrumentation cluster, 23mm rear swaybar, 245x50x16 Bridgestone Potenzas
LASTSHO
MinneSHOta
There are some gents on the V8SHO.com email list that have these thingys. They work pretty well.
Subscribe to the list....or if you already are...just ask 'em. I'm sure you'd get a concise answer.
Just an idea...
Mark
'99 Black 27K
Lots-O-Mods...
The LASTSHO's Pics
OzzmanNT
Dinwiddie, VA
I was subscribed to the V8SHO list but I did not like the email list. I really liked the message board layout better. I definatly would be interesting in picking one up just keep a check on my car at all times. I just hope the software isn't a peice of junk.
1998 Burgandy SHO (Tan leather)
K&N panel filter
Mobil 1 Synthetic Oil
waiting to see what to do next....
OzzmanNT (email: [email protected] AIM: OzzmanSHO)
http://members.tripod.com/shoturbo
LASTSHO
MinneSHOta
If I were you....subscribe back on the list for a day or so...ask the questions and wait for the answers. Then unsubscribe.
I truly wish I could help you out...but I don't have the expertise in this area.
Would an email address to someone whose had this piece work out? I could get in touch with someone who could hopefully answer your questions.
Mark
'99 Black 27K
Lots-O-Mods...
The LASTSHO's Pics
Buford
Decatur IL
Tap in is under steering column and easy to reach. product is a joy to use. With I know had intake temp to with in 1 deg using paul nimz intake design. SHO runs a lot better now in the summer
stephen newberg
Buford (Tim) !
You are with us also now. Excellent. I was missing you but have also more or less given up on the email list at v8sho.com except to check in for a day or two if I have a specific question, in the way Mark was suggesting.
So, how goes the wars?
And, what did you mean this to say, since it seems to have gotten cut up a bit:
"With I know had intake temp to with in 1 deg using paul nimz intake design. SHO runs a lot better now in the summer" ?
How is Paul's different from Porter's or my version of Porter's (straight 3" intake line from inner fender well to air box and a K&N panel, which I put it last summer)?
Oh yes, for your ongoing wheel/tire data work, the 17x8 1000 Migila wheels with the Kohmu 712 245x45x17 tires arrived and I did a test fit, though I will not put them on full time until next summer. They are 40mm offset and fit fine, with well over 1/2 inch clearence to the struts. The sidewall is so short I do not expect any real movement there, certainly not 1/2 inch, so they should not touch even under hard driving.
Again, good to have you here.
pax
smn
'98, Black
Buford
Decatur IL
Tap in (for auto tap) is right under the steering column and easy to reach. I drive around all the thime with auto tap pluged in.
The product is a joy to use. With it I know that the intake temp to with in 1 deg using paul nimz intake design. SHO runs a lot better now in the summer
Paul came over this spring an did mmy intake. He uses 6" felx elbows to relocate the SHO SHOP filter in to the inner fender.
keep an eye on your wheel bearings, Paul has rims with a offset like yours and has got some wheel bearing issues.
my 7.5" rims gain 1/4" out and 3/4" inboard. I think if yo gain the rim width all on the out side (wide track) it helps corning but caan use wheel bearings.
stephen newberg
Thanks Tim,
I will keep an eye on the wheel bearings when I put the wider rims on next spring. What specifically in the way of indicators and problems has Paul had (asidee from the fact that they will likely wear out the bearings more rapidly)?
Where did you buy the software and plug and how much did you pay?
pax
smn
'98, Black
Glebtihonniaqw
