n8rsk8r
Hey Where's my post?
EDIT: This is a list of parts, I am not selling these parts, this is what you should expect to pay for the parts listed, FYI.
This is a repost since the other post is seriously MIA
This is a part and price list from a guy I have gone through for a couple different things, and this is per Axinators write up, thanks Axinator! Good stuff bro
I posted this because I will be doing this to my transmission VERY soon, thought you guys would like to know!
Hello Nathan,
Sorry I dident get back to you sooner but this weekend was the ATRA Transmission EXPO in Las Vegas. I saw the commentary on rebuilding the AX4S, this will be a good rebuilt if you do these updates. Here is the brake down on the parts in that report, all are in stock.
Banner kit with Borg-warner high-energy direct and interm. friction's.........................$112.30 With regular Borg Warner non-high energy fractions $90.00
Steel plate modual................................................................................................$36.37
OEM Shift solenoids (3 pcs)...................................................................................$16.25 each
OEM Pressure control solenoid(EPC).....................................................................$60.38
OEM TCC solenoid (lockup)...................................................................................$25.06
OEM Speed sensor...............................................................................................$49.39
E4OD early overdrive sprag (low sprag update) Borg-Warner......................................$52.31
Drive chain OEM Morse Borg-Warner......................................................................$50.73
TRANSGO shift kit................................................................................................$53.02
OEM New forward steel piston...............................................................................$13.87
Torque converter....................................................................................................$105.00
25 spline turbine shaft (used)..................................................................................$27.90
Overdrive servo molded piston (we recommend this)...................................................$4.91
SHO intermediate clutch molded rubber piston (we recommend this)............................$9.95
Total before tools and shipping w/ high-energy kit........................$649.94 w/o high-energy$627.64
The tools in this report we do not stock but we can order them but they must be prepaid. Here are the prices,
Lip seal installer protector kit ATEC # T-2400............................................................$78.95
Snapress by hagerty ATEC # T-0158-SP..................................................................$118.21
ATSG Tech manual (we have in stock)......................................................................$20.00
Hope this helps some of you!!
Hello Nathan,
