92ShoOff
Hey guys I've unfortunately only had a few minutes of time on my hands the past few days and I've gotten frustrated and have given up twice now trying to install these couplers on the intake runners and butterflies.
I had the silicone couplings sitting out in the sun for 15 minutes prior to working with them, in order to make them a little more pliable. I used a little vaseline and when I put the couplings on the runners they keep sliding off because the diameter of the couplings is too small. I'll get the band clamp on them nice and tight and the vaseline only helps them slide back off without effort. I then tried installing a coupling on the butterfly side first. Once you get the coupling on there the other side that would go on the runner shrinks down so small that there's no way they'll slip over the runner.
Any advice on how to succesfully install these things?? I would've never imagined them to be THIS difficult to where I had to resort to asking someone else how to do it. But the INSIDE diameter on these couplings is the same inside diameter as the runners, and as thick as the couplings are it's making it a hard time for me.
Thanks,
Andrew
Thanks,
Andrew
