CincyBearcat
How many miles did you put on your 94 SHO ATX before it needed tranny work?
~Mike
~Mike
What year was the tranny that your dealer put in there? If it wasn't a newer unit with the factory updates, then that could be part of the problem right there.SHOLOVER:
My 93 has 91k and i have had 4 trannys from my ford dealer all ford rebuilds When I got it it had 86k two months later it would slip like mad when you would punch it on the freeway the next one they gave me lasted one more month when it started doing the loudest shifts I have ever heard and I mean bad and then the next destroyed the sprag from what my ford tech said. It wouldnt even move now this one seems ok but I sweat when i reach for the N2O switch so I havent squeezed I am thinking about finding a used tranny and having my friends at school go throught it and the swap does anyone know were I could get heavy duty clutches and sprrags for the axods thumbs_u burn_out shoot
That's because the '94-'95 ATX's are stronger than the '93's. True, the computer definitely helped sort out some issues that people experienced with the H3Z variant PCM's, but it's a known fact that Ford upgraded the ATX's in '94, partly due to the fact that warranty work on the '93's was going to cost them a pretty penny.stevetatro:
I don't know why people say the '94-'95 is a stronger tranny than the '93. I've seen many '94's go out with less mileage than mine (and mine was driven pretty hard) and seen some '93's last into the 140k mile range.
They may be different, but they're not necessarily any better!
The computer (D4U1 vs. H3Z) is a totally different story!
Ah, that would be my bad. I was assuming that the '93's did not receive the secondary cooler from the factory, namely because Jeremy's '93 (which has had many tranny troubles) did not have one when he bought it (that I'm aware of). I haven't seen any other '93 ATX's in person, so I wasn't 100% of my statement. Thanks for the correction.dlmech:
All the ATX's have the "extra" trans coolers on them, Including the 93's. Both of mine have them and all of them i have seen do also.
