Anyone have Ebay Indiglo Gauges?
NoSloSHO
Overland Park, KS
I have thought about buying the Speedhut guages and I just don't know if $130 is justifiable. What about those gauges that I have seen on Ebay by Initial K Auto Concepts Inc.? Anyone want to give any feedback on these? Their only like $50!
shotyme95
Cleveland, NY USA
I have them in my 95. Very easy install, and they look real cool. It took them 5 days to ship them to me in NY. The instructions suck, but it was pretty easy to figure out.
marlonius
Holden, MA
Yeah, I got a set of the Initial K ones for my 95. They look real good. I agree, the instructions sucked. But if you have even a little bit of mechanical inclination, you can figure it out. I didn't even have to pull the whole cluster. I just pulled the dash, the clear plastic lens, and the black trim panel around the gauges. Used a little double sided tape to hold them up until I could get the black trim panel back on. Ran the wires under the dash. Hooked them up to the parking lights. Checked for functionality and put the dash all back together. Took me less than an hour (I went slow because I had never disassembled the dash/cluster before). Well worth it.
jthomas68
Area 51
I just did an intake for an SHO,and the owner had them on his car.He had to take them out because they burned out with less than 100 hours on them.
marlonius
Holden, MA
whfla1:
you actually had to remove the entire dash ?.
No, just the black trim that's around the climate controls, cluster, and headlight ****. Then just the clear lens and black trim panel on the cluster.
I keep my set pretty dim. I couldn't handle the brightness with them turned all the way up. I also keep mine on green because you can hear a distinct electrical buzz when switched to blue.
crizzaSHO
Norwalk, CT
THey burn out!!???? I have them on full power and have had them for about a month now. They look great. I wish I would of waited and bought the REVERSE Indiglow gauges that are on ebay now. They look like the gauges in a mercedes.
ant-live
Durham, NC
I've had mine for install for almost a month now and the haven't burnt out, especially condering i had them wired wrong and they were on constantly. For $50, yeah i like them a lot.
SW SHO
Boss Man
Santa Fe, NM
I too have had mine installed for almost 2 months. I wired it so they are on all the time, but on the dimmest setting. If yours has burned out, maybe you have a bad batch, cuz mine are esentially on all the time night and day.
And no, it has not drained my battery.
For anyone looking for the SPEEDHUT one, I have mine for sale.
http://www.shoforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=6;t=001858
SHOmuchFUN
Hinesburg, Vt., USA
Why would you wire them so they are on night and day when it is so easy to tap into your autolamp/dimmer switch panel right below the dash? It doesn't make much sense to me. :rolleyes: I have the original SPmotorsports or cincisho guages... Never got into the indiglo, I guess I had these white things before the indiglo ones really came out. Had to remove every needle, but I can say that it is still pretty accurate. If you're around the VT area and wanna stop by, I'll give you a hand.
marlonius
Holden, MA
SHOmuchFUN:
The instructions that come with the indiglos warn not to hook them up to the stock dimmer as this can fry the gauges (there is a dimmer provided with the gauges). Mine are wired to my fogs. My fogs are modified to run with the parking lights and I use them during the day sort-of-like daytime running lights, so my indiglos are on whenever I'm driving. I keep the dimmer near 1/2 and they seem to be fine.
SW SHO
Boss Man
Santa Fe, NM
Three reasons I powered the dimmer straight to the battery:
1. My first install, I tapped into the parking wires at the pedal and must have crossed them. I ended up melting the dimmer switch. I had mounted it on the painted metal shin thing under the steering wheel. ( go ahead and laugh, i did)
2. Previous owner had run a power line from battery that was just sitting there.
3. I'm not all that electrically inclined and a tad lazy.
RI-SHO
B to the BANNED
Pawt., RI
Wouldnt wiring to the parking/head light switch on the top left hand corner be easier?
Slo-Sho
It wasn't me!
Crossroads, CNY
Well, I was perusing my electrical stash today and I came across the gauges! If anyone wants a six color epicenter it's yours plus shipping!
Daysho
Dayton, Ohio
Got mine off ebay a couple weeks ago, wired them as RI-SHO suggested and I like it. White face by day and when the auto-lamps kick on in the evening they come on automatically. I keep my guages on low green and my ford dimmer turned off as I don't like the lights behind the guages at night with the special k faces.
skippie
Monroe , MI
I have them. they look great, extremely bright at night (they can be blue or green with the switch they give you), easy to install (must remove most of the dash)...I suggest them, they are worth $50. Forget paying $130, thats ridiculous.
ant-live
Durham, NC
So, where exactly do they need to be wired for them not to stay on constantly?...I had mine wired behing the light switch also, which is the correct wire...i looked thru all kind of wiring diagrams and couldn't find the right one, cause now it drains my battery...
John
PA
I had mine wired to the MAIN LAMP switch Like RI-SHO said that is the easiest .. it has been working fine. i believe it was a orange wire i had it tapped into on my 91 .. would love to get the reverse ones for my 95 .. . oh and a good place to hide the box on a 91 anyway is like under the vent on the far left driverside behind the trim u can ..
John
Satchmoz
