Alarm help for and from everyone
K-BL
I dabble
Greenwood, USA
Hey guys, I'm in the middle of getting everything ready to wire my alarm, and I was wanting to know how many relays am I going to need? I'm going to b wiring he trunk pop, the door locks, starter ****, dome lights, and horn.
I have all the wiring diagrams, but I was just hoping you guys could help.
I found a good deal on some here, I belive these are the ones I need.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14934&item=3040131455
If you guys could help out it would be of great help.
K-BL
Slo-Sho
It wasn't me!
Crossroads, CNY
What type of alarm are you installing? Do you have factory keyless entry? Do you want the starter **** to be normally open/closed? Do you have the factory trunk pop solenoid? The door locking systems between the factory keyless equipped cars differs from the type used on the non-equipped cars. All these factors will dictate how many and what type you will need.
K-BL
I dabble
Greenwood, USA
I do have a factory keypad on the door. I don't want a starter, I want everything else hooked up. I do have electric trunk pop.
NoSlo
SHO Owner
Portland, OR
To start with, you will need two for door lock/unlock, but only if you don't have keyless entry. Keyless entry just needs (-) to the wires in the diagram to lock/unlock. If you have trunk pop from your remote or the doorpad you probably won't need these relays unless your alarm outputs (+) to lock/unlock doors, because you will need to change it to (-) with relays.
Your alarm will probably need another relay to flash the parking lights, if the brand of alarm requires one. Tap into the brown wire at drivers kick or the dimmer switch to flash the lights.
The trunk release will probably need a relay also. You want to supply +12v to the Violet/Yellow wire on the keyless module behind the back seat on the driver's side (access thru trunk).
The only other relays would be if you need to reverse the polarity of the door switches to input them to the alarm as triggers.
See www.relayapps.com for lots of disorganized relay diagrams.
Good luck!
BenBrausen
Minneapolis, MN USA
I had asked for the best locations to tap the wires I needed for my alarm but got no response. Thanks for the help. Now where's the best place to cut the starter wire? Where's the best place to put the main alarm unit?
BenBrausen
Minneapolis, MN USA
Any idea what color the door lock wires are? I'd like to tap them there they come in from the door, not in the door, is this posible? What color is the dome light wire?
quadmasta
Atlanta, GA
I IMed Ben and K-BL, I added you to my buddy list. I'll help you both whenever I can. Alarms are easy :)
SteedaSVT
Taylor, MI
Or Im me anytime on aol Kanakrysvt or MSn [email protected]
I am a MECP cert'd installer... I just put a Clifford RS2.5X in my SHO no starter **** though... Any ?'s feel free to ask..
Jason
davidcope
Council Bluffs, IA
OK maybe one of you guys can help me with this one....I want to put a disconnect switch on all 3 of my interior lights and I'm looking for a main power wire to these. Anybody know what color it is or if there even is one??
TIA
Dave
quadmasta
Atlanta, GA
davidcope:
TIA
Dave
DOOR TRIGGER|black/blue |+ |either kick
umm, if I'm not mistaken, you need to just open that circuit with a switch and it'll **** the lights. Same as closing the door.
quadmasta
Atlanta, GA
BenBrausen:
Slow down there Paco. Here's what you need. I asked Beth to post these a LONG time ago, but she never did.
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|yellow |+ |ignition harness |
| STARTER|white/pink |+ |ignition harness |
| IGNITION|red/lt. green |+ |ignition harness |
| ACCESSORY|gray/yellow |+ |ignition harness |
| SECOND ACCESSORY|black/green | |ignition harness |
| POWER LOCK|pink/yellow |*2 |either kick |
| POWER UNLOCK|pink/green |*2 |either kick |
| LOCK MOTOR|pink/black | |drivers door harness |
| UNLOCK MOTOR|red/orange | |drivers door harness |
| DISARM DEFEAT|pink/orange | |passengers door harness |
| PARKING LIGHTS +|brown | |headlight switch |
| HEADLIGHTS|red/yellow |+ |headlight switch |
| DOOR TRIGGER|black/blue |+ |either kick |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN| | | |
|TRNK/HTCH RELEASE|gray/red |+ |at release switch |
| TACHOMETER|tan/yellow *1 | |ignition coil *1 |
| BRAKE WIRE|red/lt. green |+ |at brake switch |
| HORN TRIGGER|yellow/lt. green |- |steering column |
| WIPERS|black/pink |+ |at switch |
| LF WINDOW UP/DN|yellow - red |A |drivers door switch |
| RF WINDOW UP/DN|yel/blk - red/blk |A |drivers door harness |
| LR WINDOW UP/DN|yel/blu - red/blu |A |drivers door harness |
| RR WINDOW UP/DN|yel/blk - red/blk |A |drivers door harness |
Notes:
*1 For multi-coil engines the tach is gray/orange at the DIS module on the pass side of motor.
*2 Five-wire for non-keyless, negative-pulse for the keyless versions.
myculito
