AHHH Darn bolt
zblackbeast
SHOtarded
Omaha, NE
Ok, im getting really angry... I got the sho to run, ive gotten everything done i just want to get it on the ground.. I cant get the lower control arm on the passenger side in. It seems like the ball joint?? (i think) is protruding into the hole where the bolt is suppose to go... Thats problem one, problem 2 is, i cant get the damn calipers on. the drivers wont line up and the passenger side got compressed some how a little... Help?
Clay
:laugh_ti:
K-Dawg
Treasure Coast, FL
The ball joint stud is notched for the bolt to fit. You probably don't have it in the knuckle all the way.
I don't understand your caliper problem. Sounds like you need to press the passenger piston back into the caliper.
WSC-SHO
SHO Groupie
Nebraska
The SHO piston is f-in massive! good luck pressing it back in the caliper....:thumb:
hawkeye18
Sorta cares
Norfolk, VA
Just make sure you use the brake pad (an old one, if you have it) to evenly distribute pressure on the piston.
NebraskaSHO
Harumph!
Omaha
Use a block of wood and a big C-clamp to press the piston back into the caliper. Vice grips or not using an old pad or block of wood and your capable of damaging the seal around the caliper piston.
