Aha! Found some missing horsepower!
Denny
Taurus Homeland
Atlanta, GA
My TB isn't not opening up fully! The throttle cable has strecthed, when I have the gas pedal to the floor, the TB hasn't opened up to WOT at all. There's an extra inch, inch/half in the cable, I see where it connects to the pedal, any ideas and bringing up the slack?
**** yeah I'm excited to find it! Now, I wonder would that cause stalling?
1990 SHO "The Staller"
Stock? Aftermarket clutch?
Coming soon: K&N
Big suspension repairs
80mm MAF
WHY ARE YOU STALLING SHO???
1992 3.8
16.9@81
RIP
SHOspeed93
Mc Henry, IL,
Yeah you should be able to adjust it, look by the TB where the wire is attached, Im not 100% sure about this though.
Tony
93 Green ATX
DYNO results 197 torque and 175 hp at the wheels
246 torque and 218 hp at the crank
Eibach Springs, Strut Tower Braces
2 Chambered 40 Series Flowmasters
K&N Air Filter, Boxless
and Five-speed shift **** conversion
New trans, Indilgo Gauges, A-pillar gauges
SHOcago Member
AIM: SHOspd93
RickieFrat
La Cosa Nostra
State of Corruption - RI
I always thought the cable was NON-adjustable. You might have to replace it. Its just a pin and a slot.
1992 TAURUS SHO
Sig Pic By SHOTIME (THX)
MORE INFO AND PICS
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
FRAT'S PERFORMANCE.COM
Your One Stop Source For ALL Your Audio Needs
[This message has been edited by RickieFrat (edited 01-31-2002).]
Denny
Taurus Homeland
Atlanta, GA
Any idea where to find a cable for cheap? New, not used, but without paying Ford prices!
Well I was thinking of just adding some nuts or something to where the cable meets with the pedal
Coming soon: K&N
80mm MAF
1992 3.8
16.9@81
RIP
Denny
Taurus Homeland
Atlanta, GA
Took care of the slack! I put in a metal plate on the pedal to pick up the slack, I think I got most of it, and it was only $.77 to fix
Results? I only stalled it once nailing the gas at idle! It won't die out on me now! And the SHO feels much more responsive! Louder at WOT, the TB should be opening up all the way now, if not, really close to it and it is FASTER!!!
1990 SHO
Stock? Aftermarket clutch? BAD clutch?
K&N air filter
Coming soon:Major suspension repairs
80mm MAF
Ah yes, the feeling of an open throttlebody
1992 3.8
16.9@81
RIP
