JRA2000TL
The Complainer
Pretty sure I've asked this a long time ago but still need some clarification. I replaced my blown stock sub in my 95 with a direct drop in 6" JL Audio subwoofer. I'm running a totally stock system otherwise (JBL). When I first connected the sub, it seemed to "bump" physically (i.e move or hit with the bass but I could not feel or tell that there was a sub installed by listening to the stereo). Tonight, I checked it and it's not "hitting". The whole time I've had the thing installed, it's as if I just removed the subwoofer totally. I heard something about the ohms being different on a stock vs. aftermarket sub.
Is there any way I can get this aftermarket JL sub to "hit" and hear/feel the bass like it's supposed to sound while leaving my stock deck in for cosmetic reasons? I paid a halfway decent amount for a direct drop in sub, but there's no deep bass from it.
Edit...I found my old post; folks recommended I get a new aftermarket amp. Ok...fine. Can I run the stock amp and make this work? If not, what's the cheapest/decent aftermarket amp that I can use to make this sub work as it should and can I make it work with the stock head unit and slave CD player? Yes I know I can buy a $75 Kenwood deck that's leaps and bounds better than the Ford unit and get a cheap Ebay amp and have tons better sound---but again, I want to keep the stock 95 decks if at all possible. The 89 has an aftermarket deck and I cannot find a decent 89 Ford premium deck that works; so I'm over it on that car. If I have to get an aftermarket amp, do I need a 2 channel or 4 channel? I'm clueless on audio. All I know is that on my 93 ATX I had in hs, I had a decent Kenwood deck, a small 225 max wattage amp, and 1 10" MTX blue thunder sub and it sounded perfect. I was totally happy with that set up...but I sold it years ago.
