aftermarket cams for SHO V8
1fastsho
Athens Ga
Would anyone be interested in some "hotter" cams? I am working on some for the Contour SVT and will be for the V6 SHO. I am interested in making more parts for the gen III. Let me know.
Shawn Pasley
Innovative Performance Technologies
770-725-4262
www.iptech.tv
92 SHO red/grey
3.2L Lowered compression(9:1)
stageII cams, Ported/Polished heads,Ported/polished Intake manifold(runners, endtanks, and behind the throttle body), big bore butterflies,80mm maf, LPM,equal length Long Tube Headers and custom Y pipe, Dynomax cat-back, Koni/coil-over suspension, poly-bushings everywhere,26mm Front sway bar, 28mm rear sway bar, solid subframe bushings,subframe connectors, tubular aluminum adjustable rear control arms,shortened shifter,235/45/17 comp T/A ZR's on TSW VX-1's. 15 lbs of boost here I come!
TheBigEgg
I guess the price is the final determinate in how much I'm interested, as with anything. I'm taking it off the road next year and making it my weekend driver, basically so I can do more mods to it. How much more hotter would you make them? I'd really want something just a little more than is stock. Also, how about some tubular suspension parts to replace the crappy stamped steel?
SaskSHO
Saskatchewan, Canada
Price, specs, expected performance gain?
Scott
97 SHO Black 30k
UDP
Porterized Intake W/K&N Panel Filter
Trush Turbo Mufflers
Firestone SZ50 EP 225/50/ZR16
Glebtihonniaqw
