adidas_kn
LOWSHO
Soo I am finally able to drive the SHO above 40mph. I finally got my AeroCatch hood latches installed yesterday. They look kool and funtion even better. The **** factor is def high with these when it comes time to pop the hood. He are some pix of them installed. I love them cause they actually lock and keep people out using a real key not a computer keyboard type round key.
They def secure the front of the fiberglass hood down. I had them installed in place of the stock hood height adjuster/stops. I deleted the stock hood catch to keep it from being a 3 step process to open the hood(1. go out and unlatch the locks 2. go back in and pull the hood release 3. walk back out to open the hood.) The radiator support is now smooth and clean. Well it seems that speeds of 90+mph (which is normal out here) will get the hood to shake pretty bad to the point where I'm worried it will stress crack the fiberglass. Might've just been cause of the high winds today but we'll see. I was thinking of drilling several 1/4" holes along the hoods brace(every foot or so) area and filling the hollow areas with hardening expanding foam. It gets rock hard and will help solidify the hood at speeds and not weigh that much. But most of the shaking is coming from the rear by the window. I'll do some more research and see whats up. It might also be these crappy stock flat hinges that have allot of play in them.
