FighAsHuck
I have an AEM V2 methanol kit installed on the car, wired exactly as the diagram shows. I have the yellow wire (ARM switch 12v) on an add-a-fuse into fuse 46 in the fuse box inside the car. However, the controller and pump never turn off. I have confirmed that the yellow wire from the controller goes to this add-a-fuse, but even if the car is left locked overnight, the pump and controller are still on in the morning. Do the fuses need to be inserted a certain way on the add-a-fuse? I have the 10amp for fuse 46 on the bottom and the fuse for the controller on the top, which to my knowledge is the way it's supposed to be. Not quite sure why it stays on, though.
