Advice replacing stereo in '94 SHO
Holiday
Canada
It seems the adapters for a new head unit require splicing and soldering so I'm gonna look into that. Buy a head unit, conversion kit, cage and whatnot and see how it all sounds. Then maybe look at an amp and aftermarket speakers.
Thanks for the tips!
You can get adapters for the new head unit that plug right into the factory harness. You do have to splice the adapter to the new head unit.
Tim Ferrell
Hudson FL
My gen 1, 89 has 6 speakers, 2) 3.25" in the dash, 2) 5.25" in the front doors and 2) 6"x9" in the rear deck lid.
Those front dash speakers only came with the 89-91 models
I saw those Q forms on crutchfield if you are interested. I think they are like $225-$250 though
Holiday
Canada
Anyone install them? Looks like the install lower L+R doors but it seems it might get in the way of my left foot sandwiching between foot rest and clutch pedal.
I haven't seen them in a SHO. The parking brake pedal is over there too. Says it fits though. Always found Q forms kinda pricey
Holiday
Canada
So there doesn't seem to be any rails or support of any kind for a head unit currently in my car. I assume I'm looking at a cage or kit of some kind to support the single DIN head unit?
Yes. A cage is used. You can always fab up something with metal straps and find/make places to bolt it to, but cage is usually the route.
Holiday
Canada
So how labour intensive is installing the rear speakers? I was told it would be about an hour labor as parts have to be removed for access. Also it appears the rear deck was cut previously to accommodate 6x9.
You have to remove the plastic molding around the back to free up the rear dash pad/cover. I could do it quicker but I've done it alot of times. An hour isn't crazy. FOr me what's crazy is paying someone to to it unless I had alot of money and no time. Stereo stuff, once you map out how to install wiring (using existing and/or running new) is not a difficult thing. First run through has a small learning curve but, really, it looks harder than it actually is.
Holiday
Canada
Can anyone tell me as to the quality of the original JBL door speakers? I have an opportunity to buy the originals but I am contemplating aftermarket ones.
30 year old originals? if you need it to be all original parts then maybe a good idea. If you want to use them for audio I would get a correct size and power match for whatever head unit and/or amp you will be using
Mike976
