jmpSHO
I am about to buy the rear brake upgrade for 95 ATX and I was wondering how do I adjust the brake bias and do I actually have to adjust it?
So I won't see any benefit at all upgrading to the 11.6 in the rear?
You will get more braking in the rear and you see better stopping. If you do panic stop the ABS will kick in sooner as the rear end usually lifts in a panic situation and well your brakes will be better.
The rear upgrade is better suited to be matched with a 13" upgrade but you should still be okay.
How? All you are doing is replacing the little rotor with a bigger one.... This is very very debatable. The 11.6" rear upgrade is nothing more than an appearance modifacation.
- James
cuz overall, under normal driving circumstances, the rear brakes only do maybe 20% of the overall work...if that. ever notice how infrequent rear brakes need changing? i've had my 95 since 2005, and although i've done front brakes twice and upgraded to the 96+, i've only done the rears once, and that was shortly after i got the car cuz the calipers had seized. and i've probably put 60k on the car since then...and yes, they are in adjustment. *edit you really wanna be able to stop better, get a more aggressive pad/rotor setup and sticky tires. that'd be more effective.
- James
More a sign of the bad geometry of the Gen 1 & 2 SHO which contributes to extreme front end dive.
