Add Moog to Quick-Struts?
trainguy1989
SHOtarted
Wichita, Ks
On my 91 MTX I have the Monroe Quick-struts on all four corners. All four are brand new. I was hoping for somewhat of a stiffer ride but I keep bottoming out at fast speeds and it feels like the car rolls around corners. The Quick-Struts must not have progressive springs. I have sub-frame connectors and Strut-tower braces. Since the strut mounts and and components are new can I swap Moog springs into them? Can the Quick-struts shocks handle them?
Thanks for the help.
lowc
aka vapah lock
Quincy, massachusettes
they shouls hold the springs but fwiw i think those things are garbage and defenitly not sho worthy personaly i use the moog springs with kybs and i enjoy the ride havent tracked it so dont know how they are under those situations
shonuffmine
wildchild
sweating balls in fla.pan
Cutted Moog Cargo coils + sensatracs= WIN !!!! I put them on 2 months ago n love em!Then again it,s my hiway car but the ride is firm but not punishing.It corners well too,just need a bigger bar in the rear.
The quick-struts that I have purchased have all very definitely had progressive springs.
quick-struts do have sensa-trac shocks in them.
the amount of body roll you get in corners is not a strut issue, it is a sway-bar issue.
platoribs
Live to Drive
Plat0ribs House of SHO,il
I'm getting ready to put quickstruts around my Green car and I've been thinking about swapping in some cut eibach's for the front.
Hoping the sensatrack's will be able to hold up.
These are the cut eibach's...
CutEibach
Can someone tell me if this spring will set my ride height right... too low? too high?
I'd rather find out before I install and put everything back together, IYKWIM!
platoribs
Live to Drive
Would you kindly share your experience with quickstruts that enabled you to form this opinion.
I'm not picking on you but if you have some experience I'd like to hear it before I put QSs on my car.:thankyou:
lowc
aka vapah lock
ive used them on a number of customers cars and im personaly not a fan of them some ive put in have riden worse than the blown ones ive taken out over all i dont like the way they handle but fwiw ive had customers that love them and im sure someone else will chime in with there opinion on them
jmpSHO
Massachusetts
I used QS in the rear of my SHO a long time ago before I put the Eibachs in and I was happy with the ride but my only problem was that it sat too high in the rear so I am sure if you use Monroe QS all around your ride height will a little on the high side.
lowc
aka vapah lock
you sir are a very mean man :moon:
jk
Maybe all the quick-struts do not have the same springs because the ones I have used clearly have progressive springs with a higher rate than stock SHO springs. In fact, there is a thread on here somewhere where i posted the rates.
They do sit a little higher than stock springs for a thousand miles or so until the springs settle in.
Sensatracs are significantly better than kyb in my experience, especially if you want them to last more than 10k miles.
