AC on the fritz?
DavidT
TN
Does anyone elses AC seem to fluctuate between cold air and "not so cold" air. It almost seems (at times) that all of a sudden, the ac compressor will stop and just blow air rant
The dealer says everything is fine... headbang and double rant !
:D (like the new graemlins!)
Vroom
Un-Moderator
South Dakota
I haven't noticed a problem on my 97 SHO yet. One weird thing is that the lever on the gas level indicator varies all the time. While accelerating, it shows that I have less gas than I really have and it is only accurate when stopped or turned off because it varies while driving. Anyone else notice this? (sorry for the OT post, but it kind of relates... kind of...) :p
And one more thing... Is it officially pronounced "S.H.O" as in separate letters or pronounced to sound like "show"?
DavidT
TN
Yes, unfortunately the needle's movement is normal. Personally, I hate it.
The SHO is pronounced both ways... some favor one over the other... I like "show".
Funmart6
my name is mud
Auburn, Alabama
oh_my My fuel gauge does something like that too, but it isn't all that drastic, wonder why it does that? shrug headbang
My AC blows like a 5 dollar ******!!!! Cold as ice and won't quit!!!! No probs with that!
thumb
stephen newberg
Ladysmith, BC, Canada
The reason for the fluctuation in the gas level needle is twofold. First, like most level measures in cars, this is done via a float in the tank, but in this case the movement of the float is not highly damped. Hence you get motion related to current movement of the fluid in the tank. Gas goes forward a you stop, backward as you step on it, etc. You can use this to figure out if the float is in the front or the back of the tank, by the way. Think about it. :) Many car models have this effect, so it is not abnormal.
Second, the Gen III SHO has a -really-big gas tank for a modern car, and that accentuates the movement since there is more fluid to move and a larger area for it to move within. Having come in on fumes early in my ownership of the car, I can state that the tank appears to be of 80 liters capacity, plus a couple more in the lines and filler. For a modern car, that is a very big tank. A normal Gen III Tarus has about a 60 liter tank, if I remember right. 61, 62, I forget. To actually get the tank filled, you almost have to dribble in the last 15 liters or so, since the neck is shaped differently to deal with the larger tank.
Oh, gallons. 80 liters is about 20 US gallons, and the normal tank in the non-SHO versions are about 15 US gallons. For those of you not yet metric converted. :)
pax, smn
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
I notice the fulxuation of the gas guage. I don't trust it anymore. My gas light comes on and I still have 3.5 gallons left!! In comparison, my F350 holds about 45 gallons. oh_my
ricky
sharpsburg,nc
my fuel gauge varies more by angle car is driving than anything else. downhill gas gauge goes up, uphill or accelerating goes down. if you fill up with front down a bit you can fit it 17.5 to 18 gals if you are dead on empty [with high cost of fuel pump replacement not advisable to run that dry very often]
99V8SHO
GasOilAndTires
ricky:
Do you have a GenI or II or III?
Cuz then GenIIIs can only hold 16 gallons.
ricky
sharpsburg,nc
98 sho which takes 14 to 15 to fill 99% of the time but I have pushed the limit a couple of times and filled up after driving about 30 miles past E [4 to 5am]. again front end has to be 4 to 6 inches below rear. ps. this was at a chain gas station with state certified pumps.
stephen newberg
"Cuz then GenIIIs can only hold 16 gallons."
Well, I have put 20 gallons in, twice. Once a bit more than 20 because I had gotten down into the lines by pushing it way too far. Maybe mine just has a strange tank. But if you rely on the number supplied by Ford for a Taurus tank, I think you will be off since ours is not shapped the same. Well, mine is not, anyway. You can tell if you have them out to look at.
pax, smn
99V8SHO
GasOilAndTires
I am not calling anybody a liar, but that number seems kinda high once you get outside of the tank. One thing that anger me is the fact that the warning light comes on and I stop to fill up, only to find that I was able to put less than 13 gallons into it! WTF! Now I wait to fill up until about 50 miles after the light comes on, and even then I can only put 14.5 gallons into it.
ricky
sharpsburg,nc
one possibility for difference in gas capacity is that ford could have put the tank for the flex fuel cars on other cars also. that tank is listed at 18 gal [add 2 gals if you fill up where expansion area of tank gets used] I repeat: not a good habit to run that dry, save your fuel pump.
ricky
sharpsburg,nc
back to original question abount AC. does compessor disengage while blowing warm air? is AC control set on AUTO or other when this occurs?
Sounds like the AC may need a charge.
The gas gage needle movement is subdued by a "slosh" module, maybe yours is bad. The gas tank indeed holds close to 20 gallons. I have put that much in myself. Ford only rates it at 16 because of the expansion space needed. Also the light comes on at ~3/4 tank capacity to keep the fuel pump covered in gas.
DavidT
TN
Isn't the compressor supposed to be engaged in all modes? If not, which modes then? I believe the cold air will occasionally stop in ALL modes though.
Also, how can you tell if the compressor is disengaging?
The Carmax dealer said that the ac outlet temp was 41 F, and that the temp. dropped in less than 5 min. shrug The problem is... it will work great at times, then all of a sudden it will act like my non working gen.1 rant :D
The compressor is engaged as needed in every mode but floor and vent.
Glebtihonniaqw
