AC Door Actuator?
absurd
California
Currently having an issue with my AC. It blows cold and all, but seems to have trouble staying in the panel mode. This happens whenever I give the car gas while at a stop. I can hear a door shut and then I need to press on "floor", and "panel" again on the controls for it to blow out the vents. Otherwise, it will just blow from the dashboard onto the windshield. Is this the blend door actuator? Or is there something else for the AC direction?
Irish Pride
Irish Inside
MusicCityUSA
Sounds like you have a vacuum leak or maybe the EATC is crapping out. The mode controls are vacuum controlled. The only motor behind the dash is the blend door motor but that only affects temperature.
-Chad
absurd
California
-Chad
Thanks. I'm leaning towards vacuum but that's going to be real fun to find. I'm gonna check the line by the firewall first, but I've already replaced the one way check valve. Noticed that the old one was letting air through slightly both ways. Didn't fix the issue entirely though - oh well
SHOrod
Torrie Tuned
Cedar Rapids, IA
I agree this sounds like a vacuum issue, and specifically the check valve for the vacuum to the EATC/surge tank. When the engine vacuum drops, the check valve should prevent the rest of the vacuum system from pulling vacuum away from the EATC system and causing the actuators to do what yours are doing. This should reduce the amount of vacuum lines you need to inspect.
-Rod
absurd
California
-Rod
I think you may be right. I did replace that black one way check valve by the firewall. The old one was letting in some air thru the other side, but the issue is still happening. Really only slams closed when I'm taking off from a stop in 1st or 2nd gear, but when I'm cruising it doesn't really occur.
BaySHO Performance
SF South Bay
You might want to drop the glove box door and look behind it. You will be able to see a couple of the vacuum pumps for the registers.
raymo23
