abs light still on (even after unplugging)
sortafamous
maryland
i unplugged the plug that all of the threads about the ABS light tell me too
the one mounted on the bottom of the big wiring block looking thing in between the air filter and the driverside headlight, it had 2 wires coming from it and was about 2 inches thick, is this the right one?
if not which one is it, and if it is the right one, how come my light is STILL on
thanks
-brian
rangerj
Brunswick, Ohio
The ABS warning light will be on whenever the ABS system is not operative, period. Fix the problem and the light will go out. rangerj
sortafamous
maryland
there has been numerous posts on here though about getting the light to turn off by unplugging the system
sortafamous
maryland
you all dont understand, there is numerous posts here that say this will turn off the light, do a search and you will see :-D
Bryan C. King
Norton, MA
Disconnecting a sensor or anything related will trigger the light on. The light only comes on when there is a problem with the ABS system. Try what projectSHO89 said, it might work. If not fix your ABS system and the light will go out :)
qiksho
SHO Addict
Fargo, North Dakota
Pull the light bulb :D
That is what I am going to do once I get my white face gauges.
I would rather not have abs anyway :finger:
1993MTXSHO
Its a Taurus...
Jersey
:thumb: less weight too pull all the abs junk off the car:salute:
