A few OIL questions here...
SHO SPD
SHO member #480
Naples, Florida
First off, I have never ran Castrol GTX in my SHO, not the 89, or this 93.. I am a little optimistic on switching to it (even after the GREAT pics).. I have always ran Valvoline Durablend, or Valvoline Syntec (full synthetic) But on this 93 it looks a rather dirty inside the oil fill hole.... I dont know what was ran in this before me, but if I switch to Castrol, will it clean it up inside, and will it help?? is it REALLY the best oil?
Rob94
Northbridge MA
It's all a matter of preference, although Castol GTX is an excellent motor oil. Just my opinion of course.
underdog1924
Haverhill, MA
Many oils are good...you just have to keep up with regular changing of it. I run Mobil 1 and believe everything runs quite well with it. Amsoil is also a very good oil but quite expensive.
fordfanatic4ever
middletown, ri
this is more a question, is it ok to use 10w-30 Mobil 1 synthetic? I ask because my local BJ's sells it for 13 bucks for 6 qts.
thanks
Terry
Dave Ladely
Seattle, WA
I consider 10-30 Mobile to be preferred, especially since it is a synthetic and the 10 weight of that is about equal in viscosity to the 5 in regular oil. Best not to use 10-40 as so called "improvers" are added,which have negative effects. Mobile 1 is one of the very best without ripping off. I have used it since it came out around 30 or more years ago, found it as good or better than others.
cheers
dave in Seattle
Dave Ladely
Seattle, WA
cheers
dave in Seattle
Dave Ladely
Seattle, WA
cheers
dave in Seattle
Satchmoz
