Ok, this is what I found when I removed the clutch, this means I need a new clutch? I don't see any shims unless I'm overlooking something. I've never worked on a/c before other than vac and refilling. Before the a/c clutch would sometimes work when cold, but the air never really got cool, also broomstick would pop it on. I put it back together and it doesn't engage at all. A/C is 35psi on the low side so it is ok.
